I ave an event which turns on my TV. That triggers another event, which is supposed to wait until the TV has turned on then run more commands. I have tried triggering this with the wattage, my TV is 200 Watts or more when on. I thought the events below would do that, but they don't seem to do that
Event - wait until not working
Originally posted by mikee123 View PostI ave an event which turns on my TV. That triggers another event, which is supposed to wait until the TV has turned on then run more commands. I have tried triggering this with the wattage, my TV is 200 Watts or more when on. I thought the events below would do that, but they don't seem to do that
It looks like you shouldn't call the second event from the first, instead just let the second event run, since it is looking at a condition that would be true if the first event is triggered. If the TV becomes on and the BBC1 virtual device is on, the actions would be performed. You will only need some logic to prevent the second event from running every time the TV wattage changes but is still greater than 150 watts. I would use an Easy Trigger Trigger "If Energy Lounge Watts TV has been in the range [150,1000] for exactly 00:01:00.
