Disable Event from HS3 Touch?
    I would like to create a button that enables or disables another event.
    Specifically I have an event that announces a visitor at the front door went a motion sensor is triggered.
    There are times where we entertain and a stream of people constantly arrive. I would like to easily disable the announcement from a control on my wall mounted Ipad.
    I looked through available event commands and do not see a way. Has anyone done this with their system?
    You should be able to run two script commands from HS Touch:
    &hs.DisableEvent "evening"
    &hs.EnableEvent "evening"
    replace "evening" with the name of your event.
    Cheers
    Al
      Thanks. I have not ventured into scripts yet. But this looks pretty basic.
      Do I need a vb editor to create the script file?
      Or can I just use a text editor and give the file a .vb extension?
        You don't need to create a script file. These commands can be used in HS Touch direct. I don't use HS Touch (have played with it in the past), but you can add a command in the designer to a button in this format AFAIK:
        [$SCRIPT=&hs.disableevent "evening"]
        Someone with HS Touch experience can hopefully jump in if you can't find where to add it.
        Cheers
        Al
          Another option that you can do that I have for the same reason (I didn't realize there was a command for scripts to disable events) is create a virtual device that you can turn on and off and make it a condition to the event to run.
            Thank you for the suggestions. I believe I can figure out the next step.
              I just setup an event to do whatever I need to do. So two event, one to disable the event and a second to enable. You don't need a script as stated above.
              The in HSTouch, your buttons will execute the appropriate event.
              Works well.
              Barry
