Hello-
I created a set of status graphic icons that I would like to share with the HS community.
My goal was to build a family of icons with a consistent design style that draws on Google's material design philosophy. I rendered the icons at 256px which scales very nicely to the 32px size that HS3 uses on the web interface. Every icon in the Contemporary set (as of this posting) maps one-for-one to an icon in the Simple Lines set.
I built these icons for my use case and I am happy to share them with you. The colors I chose are a bit brighter than the contemporary palette and use long shadows to make sure the icons can pop even against the lighter colors. Here is my going-in argument on the use of colors:
Grey – Indicates normal or off… blends into the background when attention is not needed
Yellow – Lighting: Note that the default on & off icon images are lights, not a power symbol.
Green – Safe: Security System armed or locked
Orange – Caution: Attention needed or zone open
Red – Warning: Alerts & Alarms
Blue – On: I wanted to use green, but used blue instead to differentiate from security systems
Black – Off: I wanted to quickly be able to see the state of my wall dimmer scenes. I mapped blue to the “on” scenes and black to the “off” scenes. I also included icons in black for things that have an off state.
Purple – Media: It’s the color that the contemporary icon set uses. I adjusted the color slightly to integrate with the palette I used.
Many of the icons have multiple colors for use in whatever scenarios you may find. For instance, the default central scene icons are the base light grey, but for my switches I went through and mapped all “on” scenes to blue icons and “off” scenes to black icons. This allows me to tell the current scene at glance, and I don’t have to read the actual status to tell if it was toggled on or off.
Here is the link to the files:
https://drive.google.com/open?id=1d0...-fCI9L6Qto5d4k
Inside, there is a folder labeled Simple Lines Icons along with some instructions to get you going.
Looks like there may be a trick to downloading the icons:
Enjoy!
-Jon
Updates:
2020-06-11: Added Scenes 6-8 & Outside Temperatures (C & F)
2022-01-03: Added Network, Ethernet, POE, Printer & WiFi
2022-05-30:
Added unlock.png to the Simple Lines (it's why there was one less between the two folders... same icon as unlock.gif)
Added Outside Temperature down to -40 (C & F)
Added 4 new season icons
Added gate and shed icons
Added new colors such that all appliance, fan, network and utility icons have grey, red, yellow, blue and green.
Originally posted by ts1234
View Post
-Jon
Updates:
2022-05-30:
