Hope someone can help with a baffling problem I am having on my SEL. I am experiencing occasional random HS3 crashes caused by an IO Exception related to Gmail. Has happened twice in last 2 months. The first after 20 days uptime, the second after 10 days uptime. Whenever this error occurs, HS3 goes down completely. The Linux OS is still operational at this stage. Re-powering brings HS3 back up.
Here is the error ...
Apart from this occasional error, Gmail is working fine in the system. It checks for email every minute and triggers using email headers work fine.
Anyone have any ideas why this error is occurring, and even more importantly why would it bring down HS3?
Cheers
Andrew
Current Date/Time: 2/5/2017 5:52:39 PM
HomeSeer Version: HS3 Standard Edition 3.0.0.297
Linux version: Linux hometrollerSEL 3.16.0-031600-generic #201408031935 SMP Sun Aug 3 23:56:17 UTC 2014 i686 i686 i686 GNU/Linux System Uptime: 0 Days 0 Hours 43 Minutes 58 Seconds
IP Address: 192.168.100.101
Number of Devices: 173
Number of Events: 169
Available Threads: 199
Enabled Plug-Ins
2.0.35.0: BLLAN
3.0.0.5: CM15A
1.0.0.0: drhsEventEnabler
3.0.0.68: HSTouch Server
3.0.5917.35093: UltraLog3
3.0.6119.21453: UltraNetCam3
3.0.1.98: Z-Wave
Unable to log into Gmail server: Authenticate as SSL client failed. You might be connecting to non SSL port.:Inner Exception: System.IO.IOException: The authentication or decryption has failed. ---> System.NullReferenceException: Object reference not set to an instance of an object at System.Security.Cryptography.X509Certificates.X509Chain.get_ Roots () [0x00000] in :0 at System.Security.Cryptography.X509Certificates.X509Chain.get_ CertificateCollection () [0x00000] in :0 at System.Security.Cryptography.X509Certificates.X509Chain.Find Parent (System.Security.Cryptography.X509Certificates.X509Certifica te2 certificate) [0x00000] in :0 at System.Security.Cryptography.X509Certificates.X509Chain.Buil dChainFrom (System.Security.Cryptography.X509Certificates.X509Certifica te2 certificate) [0x00000] in :0 at System.Security.Cryptography.X509Certificates.X509Chain.Buil d (System.Security.Cryptography.X509Certificates.X509Certifica te2 certificate) [0x00000] in :0 at System.Net.Security.SslStream+c__AnonStorey0.<>m__1 (System.Security.Cryptography.X509Certificates.X509Certifica te cert, System.Int32[] certErrors) [0x00000] in :0 at Mono.Security.Protocol.Tls.SslClientStream.OnRemoteCertifica teValidation (System.Security.Cryptography.X509Certificates.X509Certifica te certificate, System.Int32[] errors) [0x00000] in :0 at Mono.Security.Protocol.Tls.SslStreamBase.RaiseRemoteCertific ateValidation (System.Security.Cryptography.X509Certificates.X509Certifica te certificate, System.Int32[] errors) [0x00000] in :0 at Mono.Security.Protocol.Tls.SslClientStream.RaiseServerCertif icateValidation (System.Security.Cryptography.X509Certificates.X509Certifica te certificate, System.Int32[] certificateErrors) [0x00000] in :0 at Mono.Security.Protocol.Tls.Handshake.Client.TlsServerCertifi cate.LocalValidation (Mono.Security.Protocol.Tls.ClientContext context, AlertDescription description) [0x00000] in :0 at Mono.Security.Protocol.Tls.Handshake.Client.TlsServerCertifi cate.validateCertificates (Mono.Security.X509.X509CertificateCollection certificates) [0x00000] in :0 at Mono.Security.Protocol.Tls.Handshake.Client.TlsServerCertifi cate.ProcessAsTls1 () [0x00000] in :0 at Mono.Security.Protocol.Tls.Handshake.HandshakeMessage.Proces s () [0x00000] in :0 at (wrapper remoting-invoke-with-check) Mono.Security.Protocol.Tls.Handshake.HandshakeMessage:Proces s () at Mono.Security.Protocol.Tls.ClientRecordProtocol.ProcessHands hakeMessage (Mono.Security.Protocol.Tls.TlsStream handMsg) [0x00000] in :0 at Mono.Security.Protocol.Tls.RecordProtocol.InternalReceiveRec ordCallback (IAsyncResult asyncResult) [0x00000] in :0 --- End of inner exception stack trace --- at Mono.Security.Protocol.Tls.SslStreamBase.AsyncHandshakeCallb ack (IAsyncResult asyncResult) [0x00000] in :0
Cheers
Andrew
Enabled Plug-Ins
2.0.35.0: BLLAN
3.0.0.5: CM15A
3.0.1.98: Z-Wave
