I searched the board and have not found a solution that has worked.
I have one Cooper RF9540 and as of yesterday it's status is unknown. I tried:
Test Connectivity - results: "Failed to reach node 7"
Optimize - results: "Optimization not executed, cannot reach node."
Audit This Node - results: "HomeSeer was NOT able to send a frame to the node."
HomeSeer attempted two-way communication with the node to test routing and was NOT successful - method used: MFG Information"
I have had this issue in the past with a Homeseer switch which I resolved by resetting the power to the circuit. Tried it with this switch, did not fix it.
What should I try next?
Jim
Jim
