Contacting HomeSeer This Week
See more
See less
Z-Wave Warning : Secure message received
  • Z-Wave Warning : Secure message received
    I am getting this error message on a few nodes:
    Z-Wave Warning New Interface : Secure message received from node 63. It was successfully decrypted but the data sequence ID is out of sequence. (Not Processed)
    Not sure what to make of it...
    I have a Aeon Labs energy meter, which used to work and report power usage to my HS3. This has stopped working, and I am warnings like this in the log, turning the power on and off to the Aeon does not solve the problem, nor do rescans
    Apr-23 18:14:07 Z-Wave Warning New Interface : Secure message received from node 13. It was successfully decrypted but the data sequence ID is out of sequence. (Not Processed)
    Apr-23 18:14:02 Z-Wave Warning New Interface: Unhandled frame for command class: 175 Received on interface New Interface Source Node: 13
    Apr-23 18:14:02 Z-Wave Warning New Interface : Secure message received from node 13. It was successfully decrypted but the data sequence ID is out of sequence. (Not Processed)
    Apr-23 18:13:57 Z-Wave Warning New Interface: Unhandled frame for command class: 191 Received on interface New Interface Source Node: 13
    Apr-23 18:13:57 Z-Wave Warning New Interface : Secure message received from node 13. It was successfully decrypted but the data sequence ID is out of sequence. (Not Processed)
    Apr-23 18:13:52 Z-Wave Warning New Interface: Unhandled frame for command class: 165 Received on interface New Interface Source Node: 13
    Apr-23 18:13:52 Z-Wave Warning New Interface : Secure message received from node 13. It was successfully decrypted but the data sequence ID is out of sequence. (Not Processed)
    Apr-23 18:13:49 Z-Wave Warning New Interface: Unhandled frame for command class: 178 Received on interface New Interface Source Node: 13
    Apr-23 18:13:49 Z-Wave Warning New Interface : Secure message received from node 13. It was successfully decrypted but the data sequence ID is out of sequence. (Not Processed)
