hs.StringItem replacement
  • hs.StringItem replacement
    I have a HS2 script I'd like to convert to HS3 but noticed that hs.StringItem no longer exists. Can someone suggest a workaround to the section below which uses it?
    PHP Code:
    For I=0 to UBound(section_items)
    Dim the_date_time As String
                    Dim the_name
    As String
                    Dim the_note
    As String
            the_date_time
    hs.StringItem(section_items(I),1,"=")
    the_name hs.StringItem(section_items(I),2,"=")
    the_note hs.StringItem(section_items(I),3,"=")
                    If
    the_name "SUMP OFF" Then
                         dev_string
    dev_string "<img src=\MyImgs\led-red.gif> <small>" the_name " @ " the_date_time " " the_note "</small> <br>"
    Else
    dev_string dev_string "<img src=\MyImgs\led-green.gif> <small>" the_name " @ " the_date_time " " the_note "</small> <br>"
    End If
    Next
    Robert
    Check out the .net split function. It's nearly identical.
    https://www.dotnetperls.com/split-vbnet
    -Rupp
      When HS3 first came out, I wrote a function to replicate hs.Stringitem.
      Place the following code at the bottom of your script. Then change any references in your script from hs.StringItem to just Stringitem.
      Function Stringitem(ByVal Str As String, ByVal Index As Integer, Byval Sep As String) As String
      Try
          Dim Result() As String = System.Text.RegularExpressions.Regex.Split(Str, System.Text.RegularExpressions.Regex.Escape(Sep))
          Return Result(Index-1)
      Catch
          Return ""
      End Try
      End Function
      Jon
        Thank you very much Jon!
        It works perfectly..
        Robert
