Contacting HomeSeer This Week
See more
See less
Event to run every 4th Thursday
  • Event to run every 4th Thursday
    I'm trying to figure out a way to have an event run every fourth Thursday evening. I suppose if I could have an event run every 28 days and start on a Thursday and that would work as well. How is this best accomplished? Thanks!
    How about this: create a counter, call it "Week". Then create two events something like these. Add the desired actions to the 2nd event.
    The counter increments each Thursday at 6PM. When the counter reaches a multiple of 4 it triggers the 2nd event.
      You can already do this, except hat the day of the week portion cannot be the first condition. The event engine is very powerful, there are a lot of options that are available after you fill in the first condition.
      See the example below.
      I hope this helps.
      Billy Draper
        Another variant:
        Modify the first event to run at 1:00 AM on Monday. (This event just counts weeks.)
        Trigger the second event at your desired time, with the conditions that 1) the day is Thursday, and 2)the week counter is 4 or a multiple of 4.
        HS3 Pro Edition 3.0.0.548
          Here is an example of one I have used before. Hope this helps.
            Gads! Counters? Post #3 has the solution. Counters and timers can become a PITA FAST! My personal philosophy is to avoid if possible.
            Originally posted by rprade
              The problem with the method in post #3 is that it selects the 4th Thursday of the month, not every 4th Thursday. The OP sounds like a need to run every four weeks, rather than once a month.
              I agree on timers, but I find counters to be fairly well behaved and easy to manage.
                I agree, but I think the OP wants the event to run every 4th Thursday, not the 4th Thursday in each month. Post #3 is for the 4th Thursday of each month, making the event run 5 weeks apart every 2-3 months.
                The only way I can think of running it on every 4th Thursday is with a counter and at least 2 events.
                It would have to be set up just right to trigger on the first Thursday, then it would continue reliably, unless HomeSeer is down at one of the trigger times. If it misses a trigger, it will be out of sync from then on without intervention.
                Randy Prade
                Aurora, CO
                Prades.net
                  I could do with this!
                  Hi all,
                  Well Jamesk I thought about how to do this and gave up, still writing on the calendar, I need to stay at home for my medication! I hope your reason is more exciting than this.
                  Will keep an eye on the thread.
                  Peter
                    [ATTACH]60927[/ATTACH]
                    Good catch Randy, I guess that I did not read the requirement close enough... only had one cup of coffee at that time of the morning... LOL
                    Billy Draper
                      If it needs to run every 4 weeks on a Thursday then what about this way.
                        I saw where you posted that screenshot 6 posts above. That would work fine, but it would require attention from time to time to add dates. You could probably get by with editing the dates once a year, with a calendar in front of you. The two events I created above would be automatic, unless HomeSeer is down at 6:00PM on a Thursday evening. You could set the device and trigger event to: "Include in power fail recovery:" to mitigate the chances of that happening.
                        Randy Prade
                        Aurora, CO
                        Prades.net
                          Right! Every 4 weeks. Yeah, I can't think of any way to do it without a counter and multiple events either. It's the need for multiple events to clean up counters and timers that I don't like. It gets convoluted.
                            Well I would just do this with a simple script. Just run it at a set time every day:
                                Sub Main(ByVal Parm As Object)
                                    Dim DOW As Integer = DateTime.Today.DayOfWeek
                                    Dim Day As Integer = DateTime.Today.Day
                                    If Day >= 22 And Day <= 28 Then
                                        If DOW = 4 Then hs.TriggerEvent("MyEvent")
                                    End If
                                End Sub
                            Jon
                              Jon,
                              Does this script find the 4th Thursday of the month? It doesn't look like it finds every 4th Thursday.
