Event to run every 4th Thursday
  • #16
    Ahh. I've read it wrong too. It is a recurring 4 week trigger he wants....
    Jon
    • #17
      My Daily Reminders script (in the library) will do this very thing quite easily. Just set the start Date/Time and set the interval to 4 weeks (or 28 days). The script is capable of running an event on cue.
      • #18
        Would this work for you?
        Sub Main(ByVal Parm As Object)
            Dim ReminderDate As New Date(2017, 4, 27)
            Dim CompareDate As Date = Now.Date
            If DateDiff("d", ReminderDate, compareDate) Mod 28 = 0 Then
                hs.TriggerEvent("MyEvent")
            End If
        End Sub
        Greig.
        Scripts =
        Various
        • #19
              End If
          End Sub
          Greig.
          Can I just simply paste this into a .vb and save to the scripts folder? When I run the script with the New Date set to 2017, 4, 16 (as a test) and launch manually, the script runs but it does not start my event.
          When I launch the following script, my event does run so I know the path is right. Am I missing some prerequisite setup needed for this script to run? Thanks!
          hs.TriggerEvent("Timed Events RecyclingDay")
          End Sub
          • #20
            End Sub
            What is the event name? If "Timed Events RecyclingDay" is the group plus the event name, only use the event name "RecyclingDay".
            Randy Prade
            Aurora, CO
            Prades.net
            • #21
              That's only a 2 week delta, not a 4 week one. Try 2017, 4, 2 and it should trigger the event today.
              Cheers
              Al
              • #22
                Cheers
                Al
                Thanks! That was a real genius move on my part!
                Thank you all for the excellent suggestions!
                • #23
                  Wouldn't the "Cannot re-run for: " set to somewhere between 21 - 27 days work?
                  • #24
                    You can calculate the number of the week with:
                    w= DatePart("ww", Now())
                    Then, for triggering an event every 4 weeks, starting week #4
                    if (DatePart("ww", Now())) Mod 4 =1
                    If week 4 is not suitable for the first week you can use w-1 or w-2 etc.
                    PHP Code:
                    'Triggering an event every4th sunday:
                    Dim DOW As Integer = DateTime.Today.DayOfWeek
                    Dim w As Integer = (DatePart("ww", Now())) Mod 4
                    If w-4 = 1 and DOW =4 Then
                    end if
                    If you want to use HS events, you can just store w in a device once a day, then use this device value in events, that is what I use for triggering events on odd/even weeks.
                    • #25
                      Or another way with no overhead.
                      Add the following script to be run by "MyEvent"
                      Set "MyEvent" to run next Thursday by a normal 'If Time/Date is.....' trigger.
                      Now when the script runs next Thursday, it will set a new Time/Date trigger for the event in 28 days time.
                              Dim dt As Date =  DateTime.Parse(DateTime.Today.AddDays(28) & " 08:00 AM")
                              Dim dvRef As Integer = hs.GetEventRefByName("MyEvent")
                              hs.EventSetTimeTrigger(dvRef, dt)
                              hs.SaveEventsDevices()
                              hs.EnableEvent ("MyEvent")
                          End Sub
                      (Change the 08:00 AM to a suitable time)
                      Jon
                      • #26
                        This thread is an effective example of how diverse methods can be used to solve a problem in HS. I'm enjoying the creativity and am impressed by the innovative thinking. I hope there are still more suggestions to come.
                        HS3 Pro Edition 3.0.0.548
                        • #27
                          OK. Clearly taking from Jon's suggestion, here is a single event with a single Virtual Device "Recycle Day".
                          Manually turn the device on on your first recycle day and it will be on again 4 weeks later on the same day. It will repeat indefinitely. If your recycle day changes to Wednesday, turn the device on that morning and it will be every 4th Wednesday.
                          Randy Prade
                          Aurora, CO
                          Prades.net
