I've started getting this error on start-up since upgrading to .318. Anyone know what it could be?
P.S. I tried to format it better as opposed to just 1 long string.
5/1/2017 7:05:43 PM ~!~ERROR~!~System.IO.FileNotFoundException: Could not find file 'C:\Program Files (x86)\HomeSeer HS3\updater.txt'. File name: 'C:\Program Files (x86)\HomeSeer HS3\updater.txt' at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.StreamReader..ctor(String path, Encoding encoding, Boolean detectEncodingFromByteOrderMarks, Int32 bufferSize, Boolean checkHost) at System.IO.File.InternalReadAllText(String path, Encoding encoding, Boolean checkHost) at System.IO.File.ReadAllText(String path) at HSPI_SCREPOSITORY.PluginStore.GenerateUpdater()
