Contacting HomeSeer This Week
See more
See less
Updater not working.
  • Updater not working.
    Getting this:
    Please wait for the updater control file failed to be downloaded or parsed.
    Nothing I do seems to fix. What's up with this?
    thanks
    If you are running on Linux check your mono version. When I had this problem I just moved to HS3 for Linux version 3.0.0.312. HS moved the update components to SSL encrypted traffic. Versions of mono that are pre 3.8 do not come pre-packaged with SSL root trusts, and your HS3 application cannot establish the encrypted connection because it does not trust the certs that it is being given.
    I built my own RPI system and then loaded mono, a few other packages, and HS3 for Linux on top of it. I didn't know that RPI foundation's distribution for mono was statically held at 3.2.8.
    There is instructions out there to install mozilla's pre-packages SSL trusts but I was not able to get this to work. I ended up pointing my system to mono-project's distrution of mono and upgrading to version 3.12.0 (I have a post out there where I enumerate the steps I took to point to mono-project.org and statically hold to mono version 3.12.0. Let me know if you can't find it.
    Be aware if you move to mono 4.x from a 3.x environment your triggers and trigger fields will be missing in all of your events. You will end up having to rebuild your events.
      what should or shouldn't it be?
      looks like 4.2-2
      (Fedora 25)
        looks like 4.2-2
        (Fedora 25)
        Ok you are on 4.x which is good. You may need to pass the specific install command to add the mono SSL trust store. Let me look it up.
          So I run Raspbian which is based on Debian. the usage notes regarding CA certificates looks the same for both distributions on mono-project.com:
          "The package ca-certificates-mono should be installed to get SSL certificates for HTTPS connections. Install this package if you run into trouble making HTTPS connections."
          http://www.mono-project.com/docs/get...nd-derivatives
          for me the command was:sudo apt-get install ca-certificates-mono
            32-bit system right now. That MONO is only good for 64-bit.
            No go.
            Turns out, this worked:
            mozroots --import --sync
            the updates are now coming in.
            thanks for helping point in the right direction
              Interesting, that command didn't work for me. Glad you got it worked out.
