Contacting HomeSeer This Week
See more
See less
Last Change not accurate
  • Last Change not accurate
    It looks like there is an issue with the Last Change field of serveral devices. I thinks it related to events using the device as i have seen it with a device which i never used before
    Actual switch commands in log
    mei-09 14:52:04	 	Change	1e verdieping Douche Ventilatie changed from 255 to 0 (FC603F7E-025)
    mei-09 14:52:04	 	Z-Wave	Device: 1e verdieping Douche Ventilatie Set to 0
    mei-09 14:52:04	 	Device Control	Device: 1e verdieping Douche Ventilatie to Off (0) by/from: CAPI Control Handler
    mei-09 06:32:07	 	Change	1e verdieping Douche Ventilatie changed from 0 to 255 (FC603F7E-025)
    mei-09 06:32:07	 	Z-Wave	Device: 1e verdieping Douche Ventilatie Set to 255
    For example i have a device for my Shower Ventilation which was working fine until 03-May-2017 (when i upgraded to 3.0.0.318)
    I`m using this event
    IF   The event will automatically trigger every 15m, 0s
    AND IF 1e verdieping Douche Ventilatie has been On for at least 2h,45m,0s
    AND IF 1e verdieping Douche Douchelamp has been Off for at least 15m,0s
    Then Set Deviec 1e verdieping Douche Ventilatie to Off
    Then Send Email about it
    But the device status seems to be chaging every 5 minutes since the upgrade. Due to this fact my event is no longer working
    The device is controlled at 07:00 AM but the status change tells me Today 14:55:54 and is now updates to Today 15:05:57 but the device values are not changed.
    Current Polling Rates
    Current Interval:	10 Minutes, 0 Seconds
    Looks like the polling interval is causing this issue. However i need this polling interval since the device is not sending out updates on local controller (Duwi Z-Wave switch) I have changed the polling interval to 2 minutes and these are the new status values
    Today 15:09:09
    Today 15:11:10
    Today 15:13:10
    Today 15:15:10
    So this is definitely related to the polling interval
    Check the Configuration tab for the device. Make sure the last box is checked.
    HS3 Pro Edition 3.0.0.548
      That is one dumb checkbox. Why it's not checked by default is truly a mystery.
      If it ain't broke, don't fix it!
        There are a few of these unexpected default conditions lurking in the shadows. I assume they were oversights during development, but why they've persisted for over 300 version revisions is a head scratcher.
          Ya wow when you have a lot of devices this will be a PITA to go through them all to change.
            One of the prolific script writers could help with a script that would recursively go through the entire device list and tick that option. I cannot see any reason I would want the Last Change date/time to be updated when the value is set but not changed.
            I looked through the documentation to set Enums.dvMISC and all of the check boxes except "Do not update device last change time if device value does not change:" are listed. For example
            dv.MISC_Set(hs, Enums.dvMISC.NO_LOG) will set the device to "Do not log commands from this device:"
            Randy Prade
            Aurora, CO
            Prades.net
              I'm afraid it's one of the times that Visual Studio comes in handy, you can explore the options available that were not documented. That script I wrote to do the NO_LOG probably works with it just being changed to what is in this image.
              One of the uses for knowing when a device was updated regardless of whether or not the value was different would be some type of heartbeat, if you had a temperature sensor that remained fairly constant and could take a while to determine whether or not it was dead you could check whether or not a new temp has been sent to HS. There's many better ways to do that though!
              My Plugins:
              Yeelight 3P | Nanoleaf 3P
                When i mentioned "One of the prolific script writers" above, I had you in mind I'll try modifying the no_log scripts I run for Z-Wave and Arduino.
                Randy Prade
                Aurora, CO
                Prades.net
                  Using "dv.MISC_Set(hs, enums.dvMISC.SET_DOES_NOT_CHANGE_LAST_CHANGE)" works great. I just modified my Arduino and Z-Wave scripts that disable/enable logging to set the
                  do not update flag.
                  Thanks!
                  Randy Prade
                  Aurora, CO
                  Prades.net
                    do not update flag.
                    Thanks!
                    Good stuff, have faith in your scripting abilities - I'm not sure what the MyHS notify flag is for however as I don't believe that one is documented anywhere.
                    My Plugins:
                      I'm terribly weak at scripting, but this one was easy enough.
                      Randy Prade
                      Aurora, CO
                      Prades.net
