HS3PRO stopped running events and is inaccessible from Web GUI
  • IanIreland
    I think I would have a browse in Event Viewer and see if there is anything obvious in there.
  • HS3PRO stopped running events and is inaccessible from Web GUI
    All, Over the last couple of weeks my HS3Pro has stopped running events several times.
    When I try to access the Web GUI on the computer it is installed on it won't connect (I've tried the Server Port I configured it to use and the default 80). I then tried to locate it using "find.homeseer.com/". It finds it, but the link won't connect.
    My next step is to shutdown HS3PRO and restart. Then I can get in to the Web GUI but only only with the default port. Additionally, when I look at the manage plugins page, all plugins have been disabled. Devices and Events appear intact.
    So I then change the Server Port Setting back to the port I use and enable all plugins.
    It will then run fine for a day or two or three, until the same thing happens again.
    I did not have this issue until sometime after I installed V 3.0.0.318, but I don't know if that is the issue.
    Anyone have any idea's what is causing this issue?
    Forrest
