I'm having a problem using the LTM-5. I've created two events to turn the lights on and off in the Conversation Pit. The off event turn off both lights and the on event turns on the ceiling light but leaves the sconces in what ever state they were in.
When I manually run the two events everything works fine and in fact the LTM-5s light turns on and off as needed.
The problem comes in when I hit the paddle on the LTM-5, nothing happens and I don't see anything in the logs.
I've done this with my VeraLite without out any issues. The VeraLite just captured the transmission from the LTM-5 and then ran the event since the Vera was associated with the Vera. So basically I figure I'm just not setting this up correctly so that HS is getting the message.
Although I'm running the Zee S2 I think this is a general issue so I posted here.
Current Date/Time: 5/19/2017 6:09:08 PM
HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.318
Linux version: Linux HomeTrollerZeeS2V2 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux System Uptime: 1 Day 7 Hours 42 Minutes 20 Seconds
IP Address: 10.0.1.65
Number of Devices: 9
Number of Events: 2
Available Threads: 389
Enabled Plug-Ins
3.0.0.68: HSTouch Server
3.0.1.83: Z-Wave
Number of Events: 2
Enabled Plug-Ins
3.0.1.83: Z-Wave
