As I add more devices to the system I'm starting to think I need to do a better job of naming conventions as well as floor/room placements. For example a Z-Wave binary switch has the root device, the central scene device, and the actual controllable device all related to it.
Would you place all three of those items in the actual room? Or would you place only the device you use for remote control in the proper room, then move the others into some kind of virtual utility closet so they do not clutter up things like HS Touch?
For example here are a couple devices in our mud room and kitchen. There are more, these are just a sample. You can see what the poor kitchen starts to look like in HSTouch when only the "Dimmer" devices are the ones you can use to remote control the units.
Thanks for the advice or tips on what you've found helpful.
