Contacting HomeSeer This Week
See more
See less
Error - Compiling script - New SEL
  • Error - Compiling script - New SEL
    VBEN will run and VB do not
    I just moved to a SEL from a Z2. I have a simple event that calls a script. This happens with all scripts and was originally noticed on one of Jon00 scripts for Alexa.
    However compiled scripts do work.
    May-27 06:27:02	 	Error	Compiling script /usr/local/HomeSeer/scripts/wx.vb:
    May-27 06:27:02	 	Event	Running script in background: /usr/local/HomeSeer/scripts/wx.vb
    May-27 06:27:02	 	Event	Event Trigger "Utility test"
    @Mark,
    Post you script here.
    put it around the #'s (code) so that it is easier to read.
    Note that I am not really versed in VB here but posting your script here others here will look at it.
    - Pete
    Auto mator
    HS4 pro - 4.0.3.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
