Can't read some entires in the logs because of the font color
  • Can't read some entires in the logs because of the font color
    I have seen several entries in the log where the font color is white.
    I've looked everywhere but can't find out what to change or how to change the color.
    I know where the command is but not knowing which one needs changing I have no idea what to enter.
    I've even tries looking at the linux directory trying to define the control file so I can read it but no joy on that either.
    Help Please
    Well, a least I found the log file. It's at "/tmp/HomeSeerLog.hsd" but it's not much help.
    I'll keep looking.
      In the HomeSeer website, navigate to Tools, Setup. On the General tab, scroll to the bottom of the page, under Log Colors, there could be White color setup that you could change. Unless you have defined some, I believe the default is usually empty. It is worth a shot...
      Billy Draper
        Make sure you don't have any special color entries under the General tab under setup.
        If there are any entries, click the "X" to delete them. If there are no entries there, then what are the entries that are white?
        Randy Prade
        Aurora, CO
        Prades.net
          [ATTACH]61469[/ATTACH]
          I'll have to wait till I see another one. I just wish I know what the defaults were or what the key words are that you need to enter to make the changes.
            The default is no keywords and no colors. If you have keywords assigned delete them. If you enter a key word and associate a color with it, any log entry that contains that word will be in the color you assign. In my example above, I highlight any log entries containing "Z-Net" with one color and "Arduino" with another.
            Randy Prade
            Aurora, CO
            Prades.net
              Finally got some more of the unreadable messages.
              The messages seem to be Z-Wave health messages. It seems that the font color for these messages are set to white at least on the Zee S2. Can someone else please check and see if the same thing happens?
              Date/Time - Pri - Type/Error - Message/Source
              Jun-08 1:40:06 AM * Z-Wave Z-Health for Warren Family sent a No-Op command to node 25 (Downstairs Kitchen Cove Lighting) and it was successful.
              Jun-08 1:38:06 AM * Z-Wave Z-Health for Warren Family sent a No-Op command to node 24 (Downstairs Kitchen Cabinet Lighting) and it was successful.
