For some reason, my pool light switch (Zooz Zen23) lost communication with HS3. The switch itself still works, but in HS3, it shows up without a Node ID. How do I reestablish the Node ID and communication without removing and reading the switch. It's pretty far from my UZB1 controller and I would literally have to move my HS3 PC near the pool to do that.
No Node ID
Not that I can help a great deal however I have also had the same issue here - https://forums.homeseer.com/showthread.php?t=188005 - I think deleting the database as advised sorted it out.
Originally posted by mrhappy View PostNot that I can help a great deal however I have also had the same issue here - https://forums.homeseer.com/showthread.php?t=188005 - I think deleting the database as advised sorted it out.
Originally posted by Sireone View PostThanks, so if I shutdown HS3, delete the z-wave2.db file, then restart, my node should reappear? Also, is anything lost doing this? Any risks?
If you go to the z-wave tab for this device, and click the arrow to show the list of available nodes, does the prior node number for this device still show as available? If so, maybe you can just select it and do a rescan? I've never tried this, but it's worth a shot.Fred
HomeSeer Pro 3.0.0.548, HS3Touch, Zwave 3.0.1.252, Envisalink DSC 3.0.0.40, WeatherXML, Z-stick, HS phone, Way2Call
Originally posted by ITguyHS View PostIf you go to the z-wave tab for this device, and click the arrow to show the list of available nodes, does the prior node number for this device still show as available? If so, maybe you can just select it and do a rescan? I've never tried this, but it's worth a shot.
Originally posted by cowinger View PostJust a thought, could you assign it a new node id, say 20, then see if the node 17 re-appears and then re-assign it back to 17?Last edited by Sireone; June 5, 2017, 10:51 AM.
Check out the Z-Wave help
Plugins->Z-Wave->Help-Documentation
Basic Functions->Device Information and Settings->Options->Node Number
In some situations, you may want to change the node number to "No Node ID" - if the node is going to be temporarily removed, you can set the node to this option and that will prevent the plug-in from trying to communicate with the node. The controller will still try to route through the node as needed, so you should still remove the node from the network - HOWEVER - by setting the device to No Node ID first, you will prevent the plug-in from removing the device from the system, which means that events referencing the device will keep that device reference so you do not have to re-create the events. Later, when you wish to use the node again, add the node to the system, remove the device that the plug-in created new, and then return to the properties of the original device and assign the new node ID to it.
If this works, if you remove the node the device should stay and you can follow this procedure to recover without having to redo the events.
Originally posted by zwolfpack View Post... add the node to the system, remove the device that the plug-in created new, and then return to the properties of the original device and assign the new node ID to it....
Originally posted by Sireone View PostQuestion, If I remove the new device that I re-add, wouldn't that also remove the Node ID that I want to use on the old device?
1) change the node number to "No Node ID" (which for you has already been done, though not on purpose).
2) remove the node from the network. Normally this would cause the device to be deleted which would break referencing events. But if this is to be believed, in this case the device will be preserved.
3) add the node. This will result in a new device being created, with a new node number.
4) Note the node number assigned to this new device, then delete the new device.
5) return to original device and assign the new node number to it.
If it goes as advertised, you'll have a different node number but that doesn't matter.
This doesn't address your issue of possibly having to move the computer closer to the node to add it of course.
