Originally posted by zwolfpack
View Post
No Node ID
Originally posted by zwolfpack View PostWell sure, one way is to use a Raspberry Pi. That's what a Z-Net is.
Originally posted by zwolfpack View PostThe way I read it, how its 'supposed' to work is:
1) change the node number to "No Node ID" (which for you has already been done, though not on purpose).
2) remove the node from the network. Normally this would cause the device to be deleted which would break referencing events. But if this is to be believed, in this case the device will be preserved.
3) add the node. This will result in a new device being created, with a new node number.
4) Note the node number assigned to this new device, then delete the new device.
5) return to original device and assign the new node number to it.
If it goes as advertised, you'll have a different node number but that doesn't matter.
This doesn't address your issue of possibly having to move the computer closer to the node to add it of course.
This works. I added a couple extra steps to the previous post. All of my Events still worked after replacing the switches - didn't have to modify anything in the events.
I replaced a couple "Aeotec Smart Energy Swtich G2" switches with enbrighten Z-Wave Smart switches using these steps:
2) Remove/Xxclude the node from the network. Normally this would cause the device to be deleted which would break referencing events. But if this is to be believed, in this case the device will be preserved.
2b) Through the breaker to remove 120vac power to the switch. Remove old switch, install new switch and restore 120vac power.
3) Add/Include the node. This will result in a new device being created, with a new node number.
6) In the Z-Wave Tab of the original device, if there is no option to select the node number, hit the "Z-Wave Config" link which will take you to a page where you hit the "Reset Z-Wave Data" button. Wait 90 sec or so after hitting the button....... Then refresh browser and select the new node number in the original device Z-Wave Tab. Hit done.
7) In the Z-Wave Tab of the original device, hit "Rescan". Wait 60 sec or so.... This will then bring in the new features (child devices, ect) of the new Z-Wave Switch.
8) Delete any child devices that were part of the old node.
I came across the procedure above while looking for a way to update the firmware of Fibaro modules, which requires excluding from Homeseer and including on Fibaro's Home Center (Lite) to update. This way no events get lost.
So here is a modification of the above to update Fibaro modules (basically added 2c):
1) Change the node number to "No Node ID".
2) Remove/Exclude the node from the network. Normally this would cause the device to be deleted which would break referencing events. But if this is to be believed, in this case the device will be preserved.
2b) (Not always required, use when inclusion fails) Through the breaker to remove 120vac power to the switch. Remove old switch, install new switch and restore 120vac power.
2c) Add the module as a node on the HCL's Z-Wave network, then update the firmware (https://manuals.fibaro.com/knowledge...ibaro-devices/) and exclude the node from HCL. Return to Homeseer.
4) Note the node number assigned to this new device, then delete the new (master) device.
6) In the Z-Wave Tab of the original device, if there is no option to select the node number, hit the "Z-Wave Config" link which will take you to a page where you hit the "Reset Z-Wave Data" button. Wait 90 sec or so after hitting the button (or follow the Log in a different window)....... Then refresh browser and select the new node number in the original device Z-Wave Tab. Hit done.
8) (Delete any child devices that were part of the old node).
9) In case your original devices still had the original Floor names (i.e. Node x) you may want to consider renaming them to the new node number (or just give them a name that makes more sense
I'm thinking of starting to replace a bunch of older jasco/GE z-wave dimmer modules with newer leviton z-wave PLUS dimmer modules throughout my house. As others above, I don't want to break events AND keep my extensive HSTouch project running.
Two questions....
1. anyone tried this in HS4? I don't think there should be a difference from HS3, but you never know.
2. Also, any reason to think that this wouldn't work in terms of HSTouch?
Thanks.
