What useful things have some of you come up for the Press & Held / Released statuses on HS-WS100+ devices?
I have a few Philips Hue bulbs and bridge coming to play around with and decide if I want to add that kind of kit to my setup long-term.
I can't use an actual non-Philips Hue dimmer switch with them. However, the idea of using press & held to start a dim up/down command, then stop that command when the switch is released intrigues me and is something I want to explore.
Any other interesting uses you've found?
