Does the text to speech create sound files that we can re-purpose ?
Text to speech sound file available as MP3 or WAV ?
Yes. Look in the wave_files folder under the HS3 folder. Each time you have HS3 speak something, it creates both a wave file and an mp3 file. You can copy these and rename them for re-use. Probably a good idea to place any copies in a folder you create, so that HS doesn't clean them up by accident.Fred
HomeSeer Pro 3.0.0.548, HS3Touch, Zwave 3.0.1.252, Envisalink DSC 3.0.0.40, WeatherXML, Z-stick, HS phone, Way2Call
Not seeing any new WAV or MP3 files written to the wave_files folder.
I did do an upgrade from 297 to 357. That's a lot of updates so I am not sure if that would affect this.
I set an event to speak at a certain time and also manually initiated several speak events and none created a file in the queue folder.
it's strange,
I had before always that i get the spoken text in the wav folder as wav and mp3...
I'm always on windows 7...
But when i updated to a newer beta of homeseer i don't get the wav and mp3 anymore...
Is it possible to enable it from somewhere ?
Because all the spoken things like status of my network i always used the wav.. now i can't anymore..
And the script is no good alternative as i use it almost for everything that i get in speech.
regardsPreferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
