HS3 Web Interface not Responding
    Lately I've been having issues with HS3 where the web interface stops responding. Looking at some of the system logs, it seems something is out of memory? I've confirmed I have plenty of free disk space, and the Linux VM running HS3 has 2GB of memory which should be sufficient? I didn't have these issues before, only thing I have done since is add a few plug-ins and updated to the latest HS3 build. Below are some of the errors I see in the logs.
    I am running HS3 as a systemd service on Debian linux. Restarting the homeseer service resolves the problem and I can access the web interface again. How can I prevent this from happening going forward?
    Current Date/Time: 2017-11-12 8:51:12 PM
    HomeSeer Version: HS3 Standard Edition 3.0.0.368
    Linux version: Linux Si-HomeSeer 3.16.0-4-amd64 #1 SMP Debian 3.16.43-2 (2017-04-30) x86_64 GNU/Linux System Uptime: 0 Days 0 Hours 1 Minute 17 Seconds
    IP Address: 10.10.10.60
    Number of Devices: 460
    Number of Events: 114
    Available Threads: 196
    Enabled Plug-Ins
    3.0.0.56: DSC Security
    3.0.0.37: EasyTrigger
    3.0.0.38: EnvisaLink
    3.0.1.130: Z-Wave
    root@Si-HomeSeer:/home/homeseer# journalctl -f
    -- Logs begin at Sat 2017-11-11 08:55:39 EST. --
    Nov 12 19:53:28 Si-HomeSeer mono[476]: 07:53:28:5692:[Warning]->Unable to serialize PED data for device, so data will not be read WallMote 2 Switch 3 Plugin: Z-Wave
    Nov 12 19:53:28 Si-HomeSeer mono[476]: 07:53:28:5709:[Error]-> Serializing object Scheduler.clsPlugExtraDataV2 :Out of memory
    Nov 12 19:53:28 Si-HomeSeer mono[476]: 07:53:28:5710:[Warning]->Unable to serialize PED data for device, so data will not be read WallMote 2 Switch 4 Plugin: Z-Wave
    Nov 12 19:53:28 Si-HomeSeer mono[476]: 07:53:28:5731:[Error]-> Serializing object Scheduler.clsPlugExtraDataV2 :Out of memory
    Nov 12 19:53:28 Si-HomeSeer mono[476]: 07:53:28:5732:[Warning]->Unable to serialize PED data for device, so data will not be read WallMote 2 Battery Plugin: Z-Wave
    Nov 12 19:53:28 Si-HomeSeer mono[476]: 07:53:28:5737:[Error]-> Serializing object Scheduler.clsDBStoreV2 :Out of memory
    Nov 12 19:53:28 Si-HomeSeer mono[476]: 07:53:28:5738:[Error]->Data for Basement Rec Room Battery WallMote 2 Battery (559) failed a database storage test [S] and will NOT be saved.
    Nov 12 19:53:28 Si-HomeSeer mono[476]: 07:53:28:5739:[Database]->ERROR, device Basement Rec Room Battery WallMote 2 Battery failed to be updated or added to the database.
    Nov 12 19:53:28 Si-HomeSeer mono[476]: 07:53:28:5747:[Error]-> Serializing object Scheduler.clsDBStoreV2 :Out of memory
    Nov 12 19:53:28 Si-HomeSeer mono[476]: 07:53:28:5748:[Error]->Data for Foyer Root Device Front Garage HS Dimmer (56) failed a database storage test [S] and will NOT be saved.
