I have 2 identical z-wave switch that turn on different areas in the SAME ROOM. I want to use the Link Device function on EACH switches configuration page, so that if either in turned off or on it will cause the other to do the same.
My question is since each one points to the other will I end up with an "infinite loop" where the first switch being switch On will send a z-wave On command to the other switch and it will in turn send a z-wave On command back to the originator and so on....... Will there be constant z-wave traffic by linking each to the other?
