Originally posted by ajachierno
View Post
Aeotec Home Energy Meter ZW095
hello all,
I'm running into a similar problem and followed all the steps outlined here and still can't get my unit to operate correctly with reporting values.
it's a gen 1 or 2 device.... not sure, it was NOS I believe and not a gen5. anyway to know for sure? So i did n't so the association process for gen5.
Should I try that?
it does report the battery (I don't have an outlet wired in by the fuse panel yet) and it shows the "Power"....but it does not show KW Hours 1 or 2 nor does it show Watts 1 or 2.
I did go into the root device and enabled those under settings. but so far nada. it's been about 24 hours.
and
I have done multiple optimizations and everything as I've been adding new devices since adding that in. no new detections for the power monitor.
I verified the clamps on in the right direction according to the K-->L markings.
and one last thing.... when I go to look at the energy usage graphs, there are no devices listed in teh dropdown to select from
I hate this damn device!
I have tried everything mentioned and reached out to tech support (very friendly BTW). I just can't get any data out.
Before I throw it into the garbage, can someone review my setup? A confounder is that I have a backup generator but I don't think they changed anything in the panel I can see. The power to the device is coming from the red line (L1). I tried an outlet on the other line but also didn't work.
4 Photos
Originally posted by RogerL View PostWell your #2 sensor is on backwards. that's one thing. i cant seem to load the other pix on my tablet, will have to get to my PC to see the settings.
Do you have the clamps pointing in the same direction? If so, I'll open the panel and switch it.
