MESSAGE BOARD (copy/paste section below to message board posts)
Current Date/Time: 12/15/2017 7:11:04 AM
HomeSeer Version: HS3 Pro Edition 3.0.0.368
Operating System: Microsoft Windows Embedded Standard - Work Station
System Uptime: 3 Days 16 Hours 48 Minutes 27 Seconds
IP Address: 192.168.1.155
Number of Devices: 18
Number of Events: 7
Available Threads: 200
Enabled Plug-Ins
2.0.131.0: BLRadar
3.0.1.130: Z-Wave
Not sure if this is the correct forum, but didn't see a better place - please let me know and I can re-post of admin can move as needed.
I bought this Ecolink Motion Sensor (Model: PIRZWAVE2.5-ECO) from Amazon about a few months back. Hadn't really used it initially, but finally added it last month. I only have this device and a couple of socket controls for our X-mas lighting right now.
When first added, the motion sensor would report and update in my web client. But it stopped reporting a couple of weeks back (see screen shot). At that time I was reviewing the jumper settings and had taken the back off - maybe the battery too (don't recall if I removed it or not), but I thought it was working since then (though maybe not).
Now I'm thinking that it may have stopped working after removing the cover, but I can't be sure. All I can tell now is that it's not working now.
Any idea why it may have stopped working? I don't have any experience with any other Ecolink product, so not sure if removing the cover (or battery) would cause this behavior. I'd like to get it working again if there's something easy that will do so.
I'm also wondering something else on the child devices. I've attached a picture of these items. What are the differences between:
> Home Security
> Sensor Binary Motion
It seems both are motion related and update when motion passes in front of sensor. What are good use cases for one versus the other?
Similar question between Battery and Power Management Notification items. What is the difference and what would you use these for?
Dave
EDIT:
I noticed today that the Z-Wave Node Information looks odd. Nodes 1 and 3 are overlapping. 3 and 5 are the same device, but are represented differently. Could be the cause of my issue? Notice that Node 1 and 3 are "together" (technical term). I'm not sure what that is? Any way to update this? I could try to restart the machine, but I *think* I have done this in the last couple of weeks (could be wrong).
I also see node 6 isn't complete. I have no idea what happened with these devices.
I'm open to any suggestions or ideas. I'm wondering if these weird things are the cause for why node 1 is no longer communicating?
Number of Events: 7
Enabled Plug-Ins
2.0.131.0: BLRadar
3.0.1.130: Z-Wave
> Home Security
Dave
EDIT:
