I need to replace several z-wave light switches with other z-wave light switches. I don't want to remove the devices because then I have to redo all the events. So I searched this forum and found some step. The first step is going to the device properties and onto the z-wave tab. There you set the node number to "No Node ID". Later on, you are supposed to set the Node ID to the new device that replaced the old device. However, as soon as I set "No Node ID" the whole page goes blank (see attachment). Then when you do a refresh of the website the tab is completely gone. In either case, I could not put in the new Node ID. Why is this happening and how can I get the z-wave tab back?
