My system decided to stop responding the other day, so I went into the web interface and restarted the Zwave+ stick (as this has fixed the issue before) and yes, this fixed the issue.... i then restarted the PC, and now I'm getting an error coming up as the Port is already in use and I can not access the web interface any longer.
Per the instructions on the Homeseer site I turned off Windows firewall, that did nothing... i then went to: C:\Program Files (x86)\HomeSeer HS3\Config and opened the settings.ini file, but there is no port line in there to change... this is the contents of the ini:
[Settings]
gLastShutdownOK=False
gFirstTimeRun=False
gConfigFilename=HomeSeerData.hsd
gLocLabel=Room
gLocLabel2=Floor
bUseLocation2=True
bLocationFirst=False
gLongitude=50.03
gLatitude=20.22
SADProc=True
RateUpdated=True
gLastRunVersion=3.0.0.368
[Display]
gSelectedGroupWeb=All Groups
so what do i need to do to change the port?
I installed Blue Iris on the machine the day earlier, but it did not effect HS3 at that time after restarting... and just to be safe, i went ahead and Uninstalled Blue Iris, restarted and still having this issue.
Thanks all!
[Settings]
gFirstTimeRun=False
gLocLabel=Room
gLocLabel2=Floor
bUseLocation2=True
gLongitude=50.03
gLatitude=20.22
SADProc=True
RateUpdated=True
[Display]
Thanks all!
