No internet=no plugins !
    My internet connection was down this morning, and I realized all plugins where pending and HS was then almost completely down!
    My inside home-network was still ok, and I wish HS could still communicate with other devices (as Z-wave and security system)...
    I do not remember such a problem with HS before the later 3.0.0.425 update, when plugins where initializing differently.
    It is a major matter for me to have HS running without outside connection, and sure wish this could NOT happen.
    I will run away from HS if any MyHS or other outside connection would become mandatory.
    Hmmmm, I wonder..
    RJ_Make On YouTube
      @Pierre...
      Here testing your scenario with Homeseer V.435.
      Here utilize PFSense with two WAN connections (for failover).
      I will disable the WAN in the next few hours and reboot both of the Homeseer servers and watch. Might just disconnect the WAN ethernet cables rather than disabling WAN links on PFSense.
      Any dependant on the Internet plugins / functions on Homeseer should not shut it down...maybe just put errors in to the logging.
      - Pete
      Auto mator
        Tested today 25th of April, 2018 by disconnecting WAN1 and WAN2 from Firewall.
        pete# ping www.google.com
        ping: unknown host www.google.com
        Shutdown Homeseer 3 lite and rebooted server.
        Start up logs show all plugins (5) started fine here. Homeseer 3 Lite web gui looks fine.
        Apr-25 8:17:25 AM Startup Settings Loaded.
        Apr-25 8:18:06 AM Startup
        Apr-25 8:18:06 AM Startup ************************************************************ ********************
        Apr-25 8:18:06 AM Startup HomeSeer version 3.0.0.435 Edition: HS3 ZEE S2 Starting Now
        Apr-25 8:18:06 AM Startup Creating Class Objects...
        Apr-25 8:18:06 AM Startup COM port classes started.
        Apr-25 8:18:06 AM Startup Application interface class started.
        Apr-25 8:18:06 AM Startup Web server class started.
        Apr-25 8:18:06 AM Startup E-Mail SEND class started.
        Apr-25 8:18:06 AM Startup E-Mail RECEIVE class started.
        Apr-25 8:18:06 AM Startup Plug-In Interface class started.
        Apr-25 8:18:06 AM Startup Local voice recognition class started.
        Apr-25 8:18:06 AM Startup Database SAVE process started.
        Apr-25 8:18:06 AM Startup Loading configuration file ...
        Apr-25 8:18:06 AM Database Opening (Mode=Read Only) up HomeSeer database /HomeSeer/Data/HomeSeerData.hsd
        Apr-25 8:18:06 AM Database Opening (Mode=Read/Write) up HomeSeer LOG database /tmp/HomeSeerLog.hsd
        Apr-25 8:18:07 AM Database Loading Devices...
        Apr-25 8:18:08 AM Startup Creating Speaker Client Interface Object...
        Apr-25 8:18:08 AM Startup This version of HomeSeer is registered as a HS3ZEES2 version.
        Apr-25 8:18:08 AM Startup Checking for available plug-ins
        Apr-25 8:18:09 AM Plug-In Found plug-in: BLLAN, version: 2.0.40.0
        Apr-25 8:18:10 AM Plug-In Found plug-in: mcsMQTT, version: 3.2.20.2
        Apr-25 8:18:11 AM Plug-In Found plug-in: OMNI, version: 3.0.2.8
        Apr-25 8:18:12 AM Plug-In Found plug-in: weatherXML, version: 3.0.0.83
        Apr-25 8:18:13 AM Plug-In Found plug-in: X10, version: 3.0.0.46
        Apr-25 8:18:15 AM Plug-In Found plug-in: Z-Wave, version: 3.0.1.210
        Apr-25 8:18:15 AM Startup Initializing Plug-Ins
        Apr-25 8:18:15 AM Plug-In Finished initializing plug-in weatherXML
        Apr-25 8:18:15 AM Plug-In Finished initializing plug-in Z-Wave
        Apr-25 8:18:15 AM Plug-In Finished initializing plug-in OMNI
        Apr-25 8:18:15 AM Plug-In Finished initializing plug-in BLLAN
        Apr-25 8:18:15 AM Plug-In Finished initializing plug-in X10
        Apr-25 8:18:15 AM Startup HStouch server started, waiting for clients to connect.
        - Pete
        Auto mator
