Maybe it's me but below is an example of one of my scene that seems to ignore the rules.
I have a webhook that triggers from Blue Iris->IFTTT to trigger this event. The idea is if there's motion from BI, it will turn on the lights in those area only if the device is off and if the "bypass" switch is activated. This way, if we're there and manually turned on the lights, then the event will be false. But for whatever reasons, it always trigger the event regardless... Also, in the "options" I set so that it cannot be re-run for 4 minutes... ("I tried to set it for 1 day just o see) so it doesn't continue to trigger, which doesn't seems to work either.
am I taking the wrong approach here?
