Error in Startup
  • Error in Startup
    Greetings,
    Getting an error in my startup, to wit:
    Compiling script Startup.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
    This is not a critical error, execution continues normally.
    Please advise. Thanks.
    ==JJS==
    Jim Speiser
    30-year veteran of Home Automation
    Still don't know squat
    Have you modified startup.vb or is this the stock script? Did anything else change when you started getting this error?
    HS3 Pro Edition 3.0.0.548
      No, & not as far as I recall.
      Jim Speiser
        I have no idea what might be causing the problem. I'm just puzzled as to why the script was being compiled. If you have not made any changes to it, I would expect it to be compiled already.
          What system are you running HS3 on.
            It's running on a Windows 7 desktop.
            Jim Speiser
              No recurrence. Issue abandoned.
              Jim Speiser
