Open Source Influx DB Persistence PlugIn
    #31
    Can't really help you sorry. The original author of the plugin is no longer active. So unless you are handy with coding, you can download the repository from GitHub, it might be difficult to get this to work with v2 of influx.
    iCore5 Win 10 Pro x64 SSD
    HS3 Pro Edition 3.0.0.435 Windows
    BLOccupied:,Device History:,Yamaha:,UltraMon3:,mcsXap:,Restart:,UltraNetatmo3:, UltraM1G3:,Ultra1Wire3:,BLBackup:,Harmony Hub:,DoorBird:,UltraECM3:,Nanoleaf 3P:,UltraRachio3:,Z-Wave:,SDJ-Health:,BLGarbage:,Blue-Iris:,Chromecast:,Pushover 3P:,EasyTrigger:
      #32
      Seems the choices of items to save on change are; a value or a string
      What is a string ??
        #33
        Originally posted by Miamijerry View Post
        What is a string ??
        A string is a alphanumeric variable, and not a number variable. This is a basic principle of almost every coding language. I suggest you Google something like "VB variable types".
        In the case of Homeseer, which is based mostly on Visual Basic (VB), it would be the "String" property of the device or possibly the "Status" property (look at the Advanced tab of your devices). I haven't experimented with the string option of this plugin so can't be certain.
        I assume that choosing string, as opposed to value, would store data like 'On' or "Off' in Influx as opposed to values like 0 or 100.
        Perhaps doing some reading around principles of coding and visual basic would be helpful for you.
          #34
          Well +1 for a developer to picks this up.
          i must say i did test it yesterday with last version of grafana and it works nice,
          but sometimes i get these errors
          my devices are normal and have a normal value... i did double check.
          jun-09 10:28:25 Influx DB Persistence Not Recording Value for Temperature as there is no valid value to record.
          jun-09 10:28:25 Influx DB Persistence Not Recording Value for Temperature as there is no it does not have valid ranged value at 2147483647
          jun-09 10:28:25 Influx DB Persistence Not Recording Value for Humidity as there is no valid value to record.
          jun-09 10:28:25 Influx DB Persistence Not Recording Value for Humidity as there is no it does not have valid ranged value at 2147483647
          i'm using it on hs4, but needs some tweaks..
          using influx 1.8.0
          Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
          HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
            #35
            I'm just at the brink of moving to HS4, but as I use this great plugin a lot, I wonder whether anyone can confirm that this functions well with HS4?
              #36
              using influx 1.8.0
              I also experienced this problem. The solution is simple: On the plugin edit the measurement to have its min and max value to whatever you had, X 10. So if your max temperature was 45, set it to 450. The plugin doesn't know how to handle the decimal point. After that, go to Grafana, and on the SELECT line of the query, press the "+" sign and add "MATH". Then edit the (math/100) to be (math/10). And now everything should be fine.
              I must say that this is a very impressive plugin and I'm having a ball with it.
              Thank you for making it available.
              PS: It would be nice to have the ability to delete a single data point from the History page of the plugin
Name:	Screenshot 2020-09-20 101340.jpg
              Click image for larger version  Name:	Screenshot 2020-09-20 101517.jpg Views:	0 Size:	30.3 KB ID:	1420564
