Need help to setup an alarm event
    Hi all
    I'm currently trying to create an event for multiple notification.
    I was wondering if group action can help me.
    For exemple i got a couple of IF and OR IF.
    I want to have a pushover notification if any of those are triggered.
    Can i do that with group action or its better to do it one by one ?
    thx
    Because you are using plug-in generated triggers, your event is likely the best way if not the only way to do it. You cannot use Easy Trigger groups since the triggers are generated by your alarm plug-in.
    HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
        HomeSeer Events share common actions, so your pushover message would be the same, regardless of the trigger. If you want a different message based upon the alarm message that triggers it, you would either need to use a HS replacement variable in the message or create a separate event for each message.
        If this is Spud’s plug-in you might ask him if there is a message replacement variable you can use in Puhhover messages or emails.
