HS3 Pro Keeps crashing every few days
  • #16
    Originally posted by langenet View Post
    Here running .435 on Windows 2016 Server (64 bit of course), running as a Fire Daemon service.
    As you can see, it's kinda rock solid. Need to take down this weekend for updates.
    I'd go with updating the .NET framework personally...
    Robert
    System Information
    Current Date/Time: 8/17/2018 3:05:36 PM Eastern Daylight Time
    HomeSeer Version: HS3 Pro Edition 3.0.0.435 (Windows)
    HomeSeer: Is Registered
    Operating System: Microsoft Windows Server 2016 Standard - Server
    OS Version: 10.0.14393 Service Pack: 0.0
    System Uptime: 47 Days 2 Hours 40 Minutes 12 Seconds
    Bare iron or in a hypervisor?
    • #17
      Bare iron...
      • #18
        Operating System: Microsoft Windows 8.1 Pro - Work Station
        OS Version: 6.3.9600 Service Pack: 0.0
        System Uptime: 2 Days 8 Hours 26 Minutes 23 Seconds
        Mine is on ESXi. Had to reboot it a couple of days ago. First symptom for me is the APC UPS plugin loses connectivity. The daemon runs local and is fine: once this happens-- Homeseer will not shut down cleanly.
        I will try updating the .net framework like someone suggested...
        Plug-Ins Enabled:
        • #19
          I did .NET and Java updates and then have been letting HS3 running manually instead of via FireDaemon. Seems more stable!
          • #20
            I doubt very much that updating your Java JRE helped with anything related to HS. Are you running a current release of Fire Daemon?
            Robert
            • #21
              Robert
              Agreed re: Java.
              As a software dev HS3 if I recall is all .NET and I recall reading that you script in VB.
              However, might as well do Java for any other apps, and I don’t know what FireDaemon is written in.
              • #22
                Originally posted by fksk View Post
                Agreed re: Java.
                Does your ESXi Windows instance update its time with NTP?
                Does your ESXi host itself update its time as well? I think by default it does not.
                I noticed that my windows instance had a very different clock real world, and then when I ran NTP updates it would sync and then drift again quickly. I realized it was reverting to the ESXi clock. Apparently there is some interaction between the two.
                I am not 100%: but I noticed a strong correlation between my HS Freakouts and when Windows did these NTP updates... Not sure if a time change is causing some sort of race condition somewhere.....
                Plug-Ins Enabled:
