I'm testing linux HS3 (trial) on a pi3 and I'm now having trouble with hs.GetURL in my events or .vb script. No issue with same script/command on Windows HS3
On starting log I can see
My command: (works fine on windows HS3)
The error (as for the starting):
Checking the mono version i can see
Is a fresh HS3 installation on rp1.
Any help?
Thanks Cris.
EDIT: reinstalled HS3 on new raspberry raspbian jessie pixel but error again...
Compiling script Startup.vb: Visual Basic.Net Compiler version 0.0.0.5943 (Mono 4.0.1 - tarball) Copyright (C) 2004-2010 Rolf Bjarne Kvinge. All rights reserved. vbnc : Command line : error VBNC2017: The library 'Scheduler.dll' could not be found. There were 1 errors and 0 warnings. Compilation took 00:00:00.8964430
&hs.geturl("https://autoremotejoaomgcd.appspot.com","/sendmessage?key=APxxxxxxxxxxxxKLEsoxxxxxxxPN-qxxxxxxxxxxxxxxxtAZbDCxxxxOL-TKU&message=sblxxxxxmo&password=xxxxxxxx", False, 80)
Compiling script /tmp/K2.vb: Visual Basic.Net Compiler version 0.0.0.5943 (Mono 4.0.1 - tarball) Copyright (C) 2004-2010 Rolf Bjarne Kvinge. All rights reserved. vbnc : Command line : error VBNC2017: The library 'Scheduler.dll' could not be found. There were 1 errors and 0 warnings. Compilation took 00:00:00.5852600
pi@raspberrypi:~ $ mono --version Mono JIT compiler version 4.6.2 (Debian 4.6.2.7+dfsg-1) Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com TLS: normal SIGSEGV: normal Notifications: epoll Architecture: armel,vfp+hard Disabled: none Misc: softdebug LLVM: supported, not enabled. GC: sgen
Any help?
Thanks Cris.
