9 child devices created but only 7 showing
  • 9 child devices created but only 7 showing
    I have a Z-Wave device that I have updated the firmware on and re-included (a few times to see if that was the problem), I have also tried "Rescan" many times but with no luck.
    As you can see here, I'm missing Switch 2 and Switch Multilevel 2:
    There are no errors in the log, and it even shows the Switch 2 and Switch Multilevel 2:
    Aug-18 3:06:01 PM         Z-Wave    9 out of 9 Child devices of node 25 were created successfully.
    Aug-18 3:05:56 PM         Z-Wave    Getting association information for Node 25 Z-Wave Switch Binary
    Aug-18 3:05:54 PM         Z-Wave    Assigning return route from node 1 to Node 25 Z-Wave Switch Binary
    Aug-18 3:05:51 PM         Z-Wave    ZWave controller: Adding association for Z-Wave device Node 25 Z-Wave Switch Binary (Node 25, Group 4, Endpoint 4) to HomeSeer
    Aug-18 3:05:49 PM         Z-Wave    Assigning return route from node 1 to Node 25 Z-Wave Switch Binary
    Aug-18 3:05:43 PM         Z-Wave    ZWave controller: Adding association for Z-Wave device Node 25 Z-Wave Switch Binary (Node 25, Group 3, Endpoint 3) to HomeSeer
    Aug-18 3:05:41 PM         Z-Wave    Assigning return route from node 1 to Node 25 Z-Wave Switch Binary
    Aug-18 3:05:37 PM         Z-Wave    ZWave controller: Adding association for Z-Wave device Node 25 Z-Wave Switch Binary (Node 25, Group 2, Endpoint 2) to HomeSeer
    Aug-18 3:05:36 PM         Z-Wave    Assigning return route from node 1 to Node 25 Z-Wave Switch Binary
    Aug-18 3:05:34 PM         Z-Wave    ZWave controller: Adding association for Z-Wave device Node 25 Z-Wave Switch Binary (Node 25, Group 1, Endpoint 1) to HomeSeer
    Aug-18 3:05:34 PM         Z-Wave    All associations for node 25 have been retrieved successfully, it supports associations on these groups: 1, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 2, 20, 21, 3, 4, 5, 6, 7, 8, 9.
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 9 can have 5 associations, and currently has 0
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 8 can have 5 associations, and currently has 0
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 7 can have 5 associations, and currently has 0
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 6 can have 5 associations, and currently has 0
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 5 can have 5 associations, and currently has 0
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 4 can have 5 associations, and currently has 1
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 3 can have 5 associations, and currently has 1
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 21 can have 5 associations, and currently has 0
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 20 can have 5 associations, and currently has 0
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 2 can have 5 associations, and currently has 1
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 19 can have 5 associations, and currently has 0
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 18 can have 5 associations, and currently has 0
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 17 can have 5 associations, and currently has 0
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 16 can have 5 associations, and currently has 0
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 15 can have 5 associations, and currently has 0
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 14 can have 5 associations, and currently has 0
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 13 can have 5 associations, and currently has 0
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 12 can have 5 associations, and currently has 0
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 11 can have 5 associations, and currently has 0
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 10 can have 5 associations, and currently has 0
    Aug-18 3:05:34 PM         Z-Wave    Node 25 Association Group 1 can have 1 associations, and currently has 1
    Aug-18 3:05:30 PM         Z-Wave    Getting association information for node 25
    Aug-18 3:05:30 PM         Z-Wave    Processing Information for Node 25 Multi-CHANNEL Command Class of SWITCH_MULTILEVEL_V3, Endpoint 4
    Aug-18 3:05:30 PM         Z-Wave    Processing Information for Node 25 Multi-CHANNEL Command Class of SWITCH_BINARY, Endpoint 4
    Aug-18 3:05:24 PM         Z-Wave    Processing Information for Node 25 Multi-CHANNEL Command Class of SWITCH_MULTILEVEL_V3, Endpoint 3
    Aug-18 3:05:24 PM         Z-Wave    Processing Information for Node 25 Multi-CHANNEL Command Class of SWITCH_BINARY, Endpoint 3
    Aug-18 3:05:14 PM         Z-Wave    Processing Information for Node 25 Multi-CHANNEL Command Class of SWITCH_MULTILEVEL_V3, Endpoint 2
    Aug-18 3:05:14 PM         Z-Wave    Processing Information for Node 25 Multi-CHANNEL Command Class of SWITCH_BINARY, Endpoint 2
    Aug-18 3:05:14 PM         Z-Wave    Processing Information for Node 25 Multi-CHANNEL Command Class of SWITCH_MULTILEVEL_V3, Endpoint 1
    Aug-18 3:05:14 PM         Z-Wave    Processing Information for Node 25 Multi-CHANNEL Command Class of SWITCH_BINARY, Endpoint 1
    Aug-18 3:05:13 PM         Z-Wave    Node 25 is a Z-Wave Plus node. Retrieving ZWPlus Info...
    Aug-18 3:05:13 PM         Z-Wave    Node 25 is Z-Wave version: Lib: 4.33 App: 2.3
    Aug-18 3:05:09 PM         Z-Wave    Node: 25 Controls Class(es): SWITCH_BINARY, SWITCH_TOGGLE_BINARY, SWITCH_MULTILEVEL_V3
    Aug-18 3:05:09 PM         Z-Wave    Node: 25 Supports Class(es): ZWAVEPLUS_INFO, VERSION_V2, MANUFACTURER_SPECIFIC_V2, DEVICE_RESET_LOCALLY, POWERLEVEL, FIRMWARE_UPDATE_MD_V2, ASSOCIATION_V2, ASSOCIATION_GRP_INFO_V2, MULTI_CHANNEL_ASSOCIATION_V3, CONFIGURATION_V4, MULTI_CHANNEL_V3, SWITCH_BINARY, SWITCH_TOGGLE_BINARY, SWITCH_MULTILEVEL_V3, CENTRAL_SCENE_V2, INDICATOR_V2
    Aug-18 3:05:09 PM         Z-Wave    Syncing Z-Wave nodes with device list...
    Aug-18 3:05:09 PM         Z-Wave    Found 14 Z-Wave nodes
    Aug-18 3:05:09 PM         Z-Wave    Getting Z-Wave node list for network DE74246B...
    It is not a filtering issue on the device overview :-)
    It's also missing on the device information page:
    Now the device was working fine before with an old firmware, It just seems this must be a Homeseer issue since the log actually says it creates the devices but clearly doesn't?
    Anyone have any ideas besides rescan and re-include..
    What z-wave version are you on? I have had the same issue with some devices and had to go back to z-wave .190 and exclude/include (within a foot or so of controller) to get all child devices. The you can go back to the latest beta z-wave version once you are done.
      "Me too" .190 was the last good Z-Wave version for a lot of us.
