HS-DS100+ Door sensor - correct device to use?
  • HS-DS100+ Door sensor - correct device to use?
    I bought a Homeseer HS-DS100+ door sensor. It comes with the devices shown in the screenshot.
    My question is when I should use the "motion" devices vs. the "access control notification"? I'm trying to detect door open and closed. They seem identical; though I'm seeing cases where, as you can see in the screenshot, the access control notification fires closed but the motion is still detecting open. These are on fridge doors so I they are a bit less than 1cm apart; I think the difference is happening if there is slight door bounce on close.
