Make HS3 see Virtual Device as a Thermostat?
  • Make HS3 see Virtual Device as a Thermostat?
    Is there a way to fool HS3 into thinking a Virtual Device is a Thermostat?
    Let me explain, in our office we have a couple of HVAC indoor units that are currently being controlled via IR using a Global Cache interface (IR2IP), so I have a Virtual Device (slider) that triggers different events that send the corresponding IR signal (cooling setpoint) to the HVAC unit, this works perfectly.
    The problem is that, under the HSBuddy app (really like its modern look and feel compared to anything we can make under HSTouch Designer), that virtual device is seen as a lighting device:
    Click image for larger version  Name:	image_71210.jpg Views:	1 Size:	71.5 KB ID:	1245477
    Maybe making HS3 think that virtual device is a thermostat will change those 2 little light bulbs in the slider to something related to climate.
    Thanks in advance.
    Try setting the 'Control Use' on the virtual device to Cool Setpoint, see if that triggers the behavior you want.
      This sadly did not work.
      Thanks afor the help though!
