I am unable to connect my WFT 07 I had laying around to my system. I have the proper username and password entered into the settings. I am using the default config file in landscape as well. I can't seem to connect. At first I thought it might be a firewall setting. But I am able to turn off the wifi on my ipad and connect via my Mobile carrier LTE with the same credentials that are on the WFT 07. Any thoughts on where I should try to troubleshoot and make it work?
My Homeseer box is on a different VLAN but is routed properly.
Homeseer box is on a .100.xx
WFT 07 is on a .1.xx network with most of my other network devices.(WFT 07 still has a default port of 10200 set)
HStouch version is 1.0.117 on the WFT
Homeseer is 3.0.0.435
