So I've been going through all the pages in this area and can not seem to find any specifics on steps to take to help HS3 Pro function at it's max on Windows 10.
What I've done so far:
Windows 10 Pro
-Edit Power Plan > Advanced > High Performance > Hard Disk: 0 > Sleep: Never (all options) > Processor Power Management: 100% (all options)
-Device Manager > USB Controllers > (check each item under this section for Power Management tabs) > un-check "Allow the computer to turn off this device to save power".
-Device Manager > Network Adapters > (check each item under this section for Power Management tabs) > un-check "Allow the computer to turn off this device to save power".
-Create a Task in Task Scheduler to Run at Startup > un-check "End Task after 3 days" > finish creating the task > select the task >
-Turn off windows Tips: Start > Settings > System > Notifications & actions and toggle off "Get tips, tricks and suggestions as you use Windows"
-Uninstall Windows Apps: Start > Settings > Apps > Apps & features > remove all the apps you can.
Any other ideas to help stop the system from lagging or doing something other then just working on HS3 Pro?
Windows 10 Pro
- Right click on the task and "export" it
- Edit the task.xml file that you just exported
- You will find a line similar to <Priority>7</Priority>
- Change the value to a normal priority (between 4-6). A table of the potential values: TaskSettings.Priority property
- A value of 4 will have the same I/O and memory priority as an interactive process. Values of 5 and 6 will have lower memory priority
- I set it to 4
- In the task scheduler, delete the task you initially created
- In the task scheduler, in the actions area, import the task from the XML file
