So I'm trying to cleanup the system from old nodes that fried out or whatever... devices that I could not get talked to remove the node properly.
I had 6 devices in total that are gone...
HS3Pro
In HS3Pro I attempted to go into the Zwave controller interface and remove the bad nodes, it didnt work because they were not there to communicate.
I then went into the devices Zwave tab > Remove Bad node > this did not work either.
After then I just went to the device managemnt page, selected all of the items in that node, and deleted them.
At this point I thought they were gone. BUT, I went to Plug-ins > Zwave > Node Information... and all of them are still there but with no "Full Name". At this point I couldnt figure out what to do next, so did a search and found that some of you used Zensys.
Zensys
I selected the node, then hit remove... obviously nothing happened because it could not reach the node... I then hit "Remove Failed". This worked on 1 out of the 6 bad nodes. The rest of the 5 come back with "Remove Failed Node from the network failed..."
I tried restarting the ZWaveStick+ interface, restarting the Windows 10 pc I have the Stick+ in and HS3Pro on.... nothing is letting me remove those 5 devices.
Thoughts?
HS3Pro
Zensys
Thoughts?
