Well.. Have bought a logic-group LHC 5028 & LHC 5020
Output 1-7 is working just fine, but output 8-10 doesn't work on the module. Instead it controls output 1-3 !
The inputs are included as switches for some reason (Switches 11-14) haven't tested the inputs though, but they also controls output 4-7.
What on earth is going wrong?
Have tried multiple reinclusions.
Log: When is switches on input 14 (which is a input...)
Dec-16 01:39:26 | Z-Wave | Set_New_Level_SWITCH_BINARY FINISHING(H) COMMAND_CLASS_SWITCH_BINARY |
Dec-16 01:39:26 | Z-Wave | Setting device Switch 6 to value 255 Network: E60D0603 Node: 35 Device Ref: 626 |
Dec-16 01:39:26 | Z-Wave | Set_New_Level, Parent: Entre Switchnede, Child:Entre Switch 6 |
Dec-16 01:39:26 | Z-Wave | Set_New_Level_Real called for Entre Switch 6, Type=COMMAND_CLASS_SWITCH_BINARY, EndPoint=6 |
Dec-16 01:39:26 | Z-Wave | Set_New_Level_Real: Initial device is Entre Switch 6 |
Dec-16 01:39:26 | Z-Wave | Payload1 zd is not nothing |
Dec-16 01:39:26 | Z-Wave | Payload1: 20-03-FF-BF-00-DF |
Dec-16 01:39:26 | Z-Wave | Device: Entre Switch 6 Set to ON |
Dec-16 01:39:26 | Z-Wave | Frame: 60-0D-06-07-20-03-FF-BF-00-DF |
Dec-16 01:39:26 | Z-Wave | ApplicationCommandHandler from Network: E60D0603 Node: 35 HANDLING: COMMAND_CLASS_MULTI_CHANNEL_V4 Frame(7)=13 |
Dec-16 01:39:26 | Z-Wave | Setting device Switch 14 to value 255 Network: E60D0603 Node: 35 Device Ref: 634 |
Dec-16 01:39:26 | Z-Wave | Zwave ethernet: Sending to node 35 (UnSecured) CC=COMMAND_CLASS_MULTI_CHANNEL_V4 |
Dec-16 01:39:26 | Device Control | Device: Entre Switch 14 to On (255) by/from: CAPI Control Handler |
