Mono Version for HS3 on Linux
  • Mono Version for HS3 on Linux
    What is the latest version of mono that people are running HS3 on? A little while back I upgraded from mono 4 to mono 5, which was a little painful (had to rebuild all my events), so I've let it go for a while.
    I have 5.12.0.226 running on Ubuntu 16.04.5 LTS. Mono 5.18 is out now though.
    Box #1
    HS3Pro:~# lsb_release -a
    LSB Version: core-9.20170808ubuntu1-noarch:security-9.20170808ubuntu1-noarch
    Distributor ID: Ubuntu
    Description: Ubuntu 18.04.1 LTS
    Release: 18.04
    Codename: bionic
    HS3Pro:~# mono -V
    Mono JIT compiler version 5.18.0.240 (tarball Wed Jan 16 09:10:16 UTC 2019)
    TLS: __thread
    SIGSEGV: altstack
    Notifications: epoll
    Architecture: amd64
    Disabled: none
    Misc: softdebug
    Interpreter: yes
    LLVM: yes(600)
    Suspend: preemptive
    GC: sgen
    There is now a "fix" below for running ASPX pages. Works great here on Intel server but not on second HS3 box running on an Arm server.
    Box #2
    Pine64:~# lsb_release -a
    No LSB modules are available.
    Release: 18.04
    Codename: bionic
    Pine64:~# mono -V
    Mono JIT compiler version 5.18.0.240 (tarball Wed Jan 16 09:06:51 UTC 2019)
    TLS: __thread
    SIGSEGV: normal
    Architecture: arm64
    Disabled: none
    Misc: softdebug
    Interpreter: yes
    LLVM: yes(600)
    Suspend: preemptive
    GC: sgen (concurrent by default)
    The Mono "fix" for ASPX does not work on the Arm CPU at this time.
    Laptops here have been updated now to Ubuntu 18.10. Servers for time bean will remain at Ubuntu 18.04.
    - Pete
    Auto mator
    HS4 Pro - V4.0.9.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
    HS4 Lite -
      Ubuntu 18.04 LTS with Mono 5.18.0.240
        Yes here for years (since Ubuntu 14.X) have manually installed Mono...well that and moved my original Zee / Zee 2 to regular Linux (many years ago) rather than use Raspberian (that is me) on Intel hardware first then Arm hardware (but not the RPi2-3).
        I was fine not using ASPX in my Linux boxes. Bill's Mono fix now let's me use ASPX on the Intel based Ubuntu computer.
        hxxps://www.mono-project.com/download/stable/
        - Pete
        Auto mator
        HS4 Lite -
          Ubuntu server 18.04.1 LTSR. Running on an ESXi hosted VM. I added the mono project repos and installed 5.18.0.240. Works like a champ there.
          I had trouble when I upgraded from mono 3.x to 4.x. All my event triggers were missing. I was able to upgrade using the JSON event export.
            5.20.0 Preview (5.20.0.191) works perfect here.
              Without any tweaks?
              - Pete
              Auto mator
              HS4 Lite -
                The aspx patch has been applied (two months ago) before installing and it does not change , when i upgrade mono.
                So yeah this version needs the patch too.
                  Reverted back to release version. Big5 plugin had problem to start with the very last preview update, so reverted back.
