HS3 3.0.0.500 ???
  • #16
    Originally posted by baudi View Post
    That would be great
    It is here: https://forums.homeseer.com/forum/ho...23#post1017623.
    I have modified it slightly to put the info in two virtual devices and also send an email. You'd need to manually create two virtual devices and edit the script with the reference IDs for them, and also the line for sending the email with your own from/to email addresses. i have an event that runs the script on a daily basis.
    Imports System.Diagnostics
    Sub Main(ByVal Parm As Object)
        Dim logName As String = "HS3 Update Check"
        Dim Debug As Boolean = False
        Try
            'This script will download the file to check whether or not the version running is the latest HS3 version
            Dim ReplyFull As String = hs.geturl("http://www.homeseer.com", "/updates3/hs3update.txt", False, 80)
            If ReplyFull IsNot Nothing Then
                Dim SplLine() As String = ReplyFull.Split(vbCr)
                Dim LatestVersion As String = SplLine(9).Replace("Version = ", Nothing).Trim
                If Debug Then hs.writelog(logName, "Latest HS3 Version: " & LatestVersion)
                'now we have the latest version in the update.txt file, find the latest version in the HS3 EXE file
                Dim HS3VersionInfo As FileVersionInfo = FileVersionInfo.GetVersionInfo(hs.getapppath & "\HS3.exe")
                Dim CurrentVersion As String = HS3VersionInfo.FileVersion
                If Debug Then hs.writelog(logName, "Installed HS3 Version: " & CurrentVersion)
                Dim CurrentInstalledVersion As String = hs.devicestring(6349)
                Dim CurrentReleasedVersion As String = hs.devicestring(6350)
                If CurrentVersion <> CurrentInstalledVersion Then hs.setdevicestring(6349,CurrentVersion,True)
                If LatestVersion = CurrentVersion Then
                    If Debug Then hs.writelog(logName, "You Have the Latest Version Installed")
                ElseIf CurrentReleasedVersion <> LatestVersion Then
                    If Debug Then hs.writelog(logName, "You Don't Have the Latest Version Installed")
                    'hs.SendEmail("home-warning@xyz.com","homeseer@xyz.com","","","New HS3 Version Released","*** New HS3 Version Released: " & LatestVersion & " ***","")
                    hs.setdevicestring(6350,latestversion,True)
                End If
            End If
        Catch ex As Exception : hs.writelog(logName, "Error: " & ex.Message.ToString)
        End Try
    End Sub
    HS 3.0.0.548: 1976 Devices 1156 Events
    Z-Wave 3.0.1.262: 123 Nodes on one Z-Net
    • #17
      Originally posted by Uncle Michael View Post
      Shut down HS. Then double click on the file 'HS3Updater.exe' in the main HS3 folder.
      This corrected the update issue and the new mobil app is really nice!! Now how do i setup it up for different users?
      • #18
        Two other fixes that I know Rich put in but didn't make the list:
        DeleteEventByRef() now actually deletes the event from the DB (before was only removing it from memory)
        HSSentry will now respect the IP binding flag it HS is set to bind to a specific IP (before it could bind to IP B but Sentry would try to check the system on IP A and cause a restart every few minutes)
        • #19
          The update references JSON API changes... are those documented anywhere ?
          • #20
            What does the 'it' refer to? The mobile app?
            HS3 Pro Edition 3.0.0.548
            • #21
              Originally posted by langenet View Post
              To those who have already updated - particularly on Windows, I see the forum is quiet on this release. Is it because it's really that good? lol
              I'm planning on upgrading from my current very stable .435 in a couple of weeks when I have a window of time. Eventually, I'd like to make use of the new mobile app.
              Robert
              Has anyone had issues with stability of connections for android HSTouch with this upgrade? One can never be certain of cause and effect, but I have several android tablets that are now having issues staying connected, since I upgraded to .500.
              Elliott
              • #22
                End Sub
                Works great. Thank you.
