Command line upgrade
  • Command line upgrade
    I am away from home at the moment but have ssh command line access to my HS3 Linux system. Can I do the upgrade to .500 from the command line? I have already downloaded the zipped file for the upgrade.
    Steve
    I am running HS on an Ubuntu 18.04 LTS custom built system. The only option I have for upgrades is via the command line. Should not be a problem.
      sesykes71 My you're brave...
        Not that brave, I think I will wait until I get home to upgrade since I see several users with issues with events with the new version.
          Steve
          Yes, even though I'm local that is exactly what I did.
          from setup:
          backup z-wave controller
          backup database
          Shutdown HS
          SSH into linux box.
          Tar entire HomeSeer directory structure, allowing complete roll back easily.
          get the update
          extract the update
          reboot
          assuming HS3 is installed in /usr/local/HomeSeer
          Tar the entire directory
          CD /usr/local
          sudo tar -zcvf homeseer-backup-before-upgrade.tar.gz  HomeSeer
          Get the update (still in directory /usr/local)
          sudo wget http://homeseer.com/updates3/hs3_linux_3_0_0_500.tar.gz
          extract the update file (still in directory /usr/local)
          sudo tar -zxvf updates3/hs3_linux_3_0_0_500.tar.gz
          reboot the system
          sudu shutdown -r now
          EDIT : I also do a shutdown, tar HomeSeer directory and reboot before I update any plugins, so I can easily roll back if the system gets into a fubar state.
            drparker151 While that will work, HS actually includes a script that does the upgrade called updatehs.sh Just run it with the last number in the version, e.g. updatehs.sh 500 and it will download the file, unpack it, and run the installer.
            Good idea to tar the directory first as you suggest!
              bsobel Thanks. that makes a bit easier and less typing
                Originally posted by bsobel View Post
                updatehs.sh 500
                Where do I put that in terminal?
                  Where is the updatehs.sh located? I couldn't find it.
                    It should be in the directory you installed HomeSeer in. In my case /usr/local/HomeSeer.
                      I see it there but what is the command to use it. I tried sudo updatehs.sh 548 but that didn't work.
                        You have to give the path in Linux.
                        If it is in the current directory:
                        sudo ./update.sh
                        Otherwise give the full path
                        If it will not execute give execute permission to the script:
                        sudo chmod +x ./update.sh
                        Randy Prade
                        Aurora, CO
                        Prades.net
                          You want to :
                          - Go to Too.s > System > Linux Tools
                          - Login
                          - ./updatehs.sh version number
                          -Rupp
                            sudo ./update.sh
                            Do you mean ./updatehs.sh?
                              Originally posted by Rupp View Post
                              You want to :
                              - Login
                              Do you have to stop HS first?
