Shutdown politely but why
  • Shutdown politely but why
    Where should I look or what should I do to drill into why HS3 shutdown this afternoon. It started up shortly after because of HS Sentry and everything seems to be fine. Running .500
    Feb-12 17:48:01 Shutdown Shutting down all plug-ins.
    Feb-12 17:48:01 Shutdown Shutting down plug-ins ...
    Feb-12 17:48:01 Shutdown Shutdown Script Completed
    Feb-12 17:48:01 Shutdown Running shutdown script ...
    Feb-12 17:48:01 Info Plugin Chromecast with instance: has disconnected
    Feb-12 17:48:01 Shutdown Application shutdown at 02/12/2019 17:48:01
    Feb-12 17:48:01 Info Plugin EasyTrigger with instance: has disconnected
    Feb-12 17:48:00 Warning Request from UI to shutdown
    This is weird.
    My system shut down this morning. Luckily I hadn't left for work yet so a quick restart and I was back up and running.
      same here.
        Mine shutdown last night at 11:06PM Central. When it came back up, only 72 of 500+ "devices" were available. Only noticed that because when we tried to run any bedtime routine, nothing worked. Had to use a backup config, but it was OLD! Now it no longer shows the icons to add or open events. REALLY weird.
        Click image for larger version  Name:	Weirdness1.jpg Views:	2 Size:	75.9 KB ID:	1284628
          outbackrob
          BLBackup plugin
            Originally posted by logbuilder View Post
            outbackrob
            BLBackup plugin
            True. There USED to be multiple copies of the config made by HS3. Only two semi-recent ones were available. Got the devices back.... I'll be firing up BLBackup TODAY!
              BLBackup has saved me... backing up each morning at 1:00am. Wouldn't live without it!
                Doesn’t sound yours shut down gracefully. What does the log show around that time? I would check your Windows logs too.
                  Microsoft pushed out a Win10 update yesterday.
                  link
                  -Wade
                    link
                    These updates were not pushed that hard.
                    John
                      It only makes the .hsd backup file copies with a typical HS3 restart. Might be good idea to add a weekly restart of HS3 to ensure you have a more recent backup copy.
                        John
                        This may be true but depending on one's update settings it could be the culprit. It was downloaded to 3 of my Win10 PCs yesterday, but I have installation delayed.
                        -Wade
                          I have also the download delayed.
                          John
                            Hmmm, it wasn't HS3, it was the PC. I see in Task Manager that my uptime is only 22 hours which would put it right about the time of HS3 restart yesterday. However, I don't have any notification that an update was installed, in fact as far as I know, I always get told that the PC needs to restart.
                            I see security updates were installed yesterday, but I don't see the time of installation. One guess, I guess.
                              I'm not running Win 10 and I don't allow auto-updates on the HS server.
