Can no longer log in to HomeSeer using lan up address
  • Can no longer log in to HomeSeer using lan up address
    Hi folks,
    i can still use myhs.homeseer.com but since upgrading to .500 I can no longer hit the local up address directly.
    Anyone else have this problem? I don’t know why it says up address is 127.0.0.1. Not sure if that’s related.
    From the about page:
    Current Date/Time: 2/13/2019 1:46:24 PM
    HomeSeer Version: HS3 Standard Edition 3.0.0.500
    System Uptime: 1 Day 4 Hours 27 Minutes 24 Seconds
    IP Address: 127.0.0.1
    Number of Devices: 337
    Number of Events: 108
    Available Threads: 799
    HSTouch Enabled: True
    Event Threads: 0
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    In Virtual Machine: No MFG: dell inc.
    Enabled Plug-Ins
    2.0.28.0: BLOccupied
    3.0.0.56: EasyTrigger
    3.0.0.104: LutronCaseta
    3.0.0.31: Nest
    0.0.0.45: Pushover 3P
    1.0.0.7: Restart
    3.0.1.252: Z-Wave
    127.0.0.1 is the loopback address of the HS server. What is the private (LAN) address?
      did your ip address change? 127.0.0.1 is a special ip address call the loopback or localhost address. i see my real local ip address when connect locally or remotely through myHS.
        I did not change it. It should be 192.168.1.13. Why is HomeSeer confused?
          My outdated .435 shows a LAN IP Address: Do you see this?
          HS3PRO 3.0.0.435 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dot, WS+, WD+ ... on and on.
            Are you running a firewall that may need to be updated? You can turn off the W10 firewall and test.
            -Rupp
              I think the issue is with having FireDaemon run HS3 as a service. When I start HS3 manually on the desktop, it runs correctly.
                So when I run HS3 from the desktop icon, it starts up correctly and knows it's own IP Address. Now I need to figure out what is different about starting it like that.
                Current Date/Time: 2/13/2019 5:06:30 PM
                System Uptime: 0 Days 0 Hours 1 Minute 35 Seconds
                IP Address: 192.168.1.13
                Available Threads: 800
                Event Threads: 0
                Email Send Queue: 0
                Enabled Plug-Ins
                3.0.0.31: Nest
                1.0.0.7: Restart
                3.0.1.252: Z-Wave
                  *SOLVED*
                  I don't know why but I had the setting "Bind Server to IP Address" set to the IP Address of the computer.
                  Once I turned that off, HS3 went back to working via FireDaemon.
                  It still doesn't have the right IP Address in the settings, but it doesn't seem to matter.
