Log reports incorrect "controlled by" event name
  • Log reports incorrect "controlled by" event name
    I have created a number of events which control Z-Wave devices, by copying an existing event, then renaming and tweaking it. The new event works as it should, and can be called using its new name, as expected. However, when run, the Log is showing inaccurate entries. The log entry for Type = Event correctly refers to the event just run, but the resultant Type = Z-Wave entry refers to the name of the originally copied event, not the newly renamed one.
    Here's an example:
Name:	Event Log Bug.jpg
    The event that was run was "Thermostat Jim Office changed to ESM via HS". This event was originally copied from the "Thermostat Lounge changed to ESM via HS" event. Note that it's the latter that's referenced in the Z-Wave event, when it should be the former.
    Running HS3 Pro Edition 3.0.0.500 (Windows).
