HS3 restarts with two network interfaces active
  • HS3 restarts with two network interfaces active
    I have a fail over network setup on my server (Win10 PRO), whenever I activate the fail-over which is on a WIFI interface I start getting HS restarts every few minutes. It looks like HS Sentry service somehow decides that HomeSeer needs to be restarted because the system now has 2 IPs, for this same reason I cannot run HyperV on my server because it creates a virtual switch...
    With both networks active I have no issues with accessing the web server. I would like to keep using HS Sentry and still be able to have the second network active, any ideas?
    HS Sentry log:
    2/27/2019 10:26:44:HomeSeer HS3 Sentry Service Started, using IP: 192.168.1.144
    2/27/2019 10:27:05:Error accessing web server: Unable to connect to the remote server
    2/27/2019 10:27:26:Error accessing web server: Unable to connect to the remote server
    2/27/2019 10:27:47:Error accessing web server: Unable to connect to the remote server
    2/27/2019 10:28:08:Error accessing web server: Unable to connect to the remote server
    2/27/2019 10:28:29:Error accessing web server: Unable to connect to the remote server
    2/27/2019 10:28:50:Error accessing web server: Unable to connect to the remote server
    2/27/2019 10:29:11:Error accessing web server: Unable to connect to the remote server
    2/27/2019 10:29:11:Cannot access HomeSeer, shutting down system and re-starting...
    2/27/2019 10:29:11:Killing HomeSeer HS3 application
    2/27/2019 10:29:36:Starting the HomeSeer HS3 Application
    Have you tried binding HS3 to the desired ipaddress? Of course this prevents the fail over from working.
    -Rupp
      Couldn't HSSentry be updated to work in a fail over setting? Here's my primary IP address, but this secondary IP address is okay too.
        Thanks for the ideas, it looks like it might be my fault why it was doing that. I changed the IP Binding from my primary IP to "No Binding" and that has fixed my issue.
