Been using the same hourly chime since the beginning of HS3. This morning updated to V500 on Ubuntu 18.04 Linux and hear and see errors with the one liner I am running.
Specifically the first part of the chime which plays back an MP3 file.
speaks this
/HomeSeer/Media/Intel+Chime.mp3
Second part is fine:
Today is $date. The time is $time. The inside temperature is $$DVR: 2441: degrees. The humidity is $$DVR: 2444: percent. The outside temperature is $$DVR:1760: degrees. Current weather is $$DSR:1791:.
Logs show:
Mar-04 9:13:28 AM Event Event HourlyChime songandtext triggered by the event page 'Run' button.
Mar-04 9:13:28 AM Event Event Trigger "HourlyChime songandtext"
Mar-04 9:13:55 AM Event Error Event action Run Script could not be completed - action does not have a valid script file or immediate command.
Mar-04 9:14:55 AM Event Error Event action Run Script could not be completed - action does not have a valid script file or immediate command *
* this error line runs on for about 15 lines or so and I do not hear my mp3 file.
FIXED: changed it to play an audio file instead of speak an audio file. It was speaking the verbiage and erroring out with using the speak command.
NOT FIXED yet as I keep seeing the same Event error above and only running the chime once an hour.
This is filling my logs and I cannot tell the source of this error.
The error is running every minute now.
Mar-04 10:50:56 AM Event Error Event action Run Script could not be completed - action does not have a valid script file or immediate command.
Thread Pool Worker
Mar-04 10:51:56 AM Event Error Event action Run Script could not be completed - action does not have a valid script file or immediate command.
Thread Pool Worker
Mar-04 10:52:56 AM Event Error Event action Run Script could not be completed - action does not have a valid script file or immediate command.
Thread Pool Worker
Mar-04 10:53:56 AM Event Error Event action Run Script could not be completed - action does not have a valid script file or immediate command.
Thread Pool Worker
Mar-04 10:54:56 AM Event Error Event action Run Script could not be completed - action does not have a valid script file or immediate command.
Thread Pool Worker
FIXED:
There was one script running every minute for a time variable and I moved Homeseer from the root directory (/HomeSeer) to the OPT directory (/opt/HomeSeer) and the reference in HS3 was to the old configuration in the root directory. Actually every script I was running in an event errored out.
I cannot update title to this post at this time. I remember being able to do this a while ago.
speaks this
Logs show:
Thread Pool Worker
Thread Pool Worker
Thread Pool Worker
Thread Pool Worker
Thread Pool Worker
FIXED:
