HS3 Log not working
  • HS3 Log not working
    I just started getting the below errors when HS3 starts up. Everything seem to be working but the log only shows one entry (GetLog Error: database disk image is malformed database disk image is malformed). Any clues how I can fix this?
    3/7/2019 10:26:58 AM ~!~Error~!~SQL Exception adding record(s) to the LOG database(0): database disk image is malformeddatabase disk image is malformed, Code=11 SQL=
    Startup Complete, 4 errors detected, check the log for more information.
    Current Date/Time: 3/7/2019 11:36:43 AM
    System Uptime: 0 Days 0 Hours 8 Minutes 21 Seconds
    IP Address: 172.16.0.10
    Number of Devices: 415
    Number of Events: 91
    Available Threads: 400
    HSTouch Enabled: True
    Event Threads: 0
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    In Virtual Machine: No MFG: minix
    Enabled Plug-Ins
    2.0.59.0: BLBackup
    1.3.6.0: Device History
    3.1.0.13: MeiHarmonyHub
    3.0.0.31: Nest
    3.0.0.14: NetCAM
    1.0.0.7: Restart
    3.0.6.8: SDJ-Health
    3.1.0.28: Sonos
    3.0.1.256: Z-Wave
    Delete the corrupted log database file?
      Event Threads: 0
      Email Send Queue: 0
      Enabled Plug-Ins
      2.0.59.0: BLBackup
      3.0.0.31: Nest
      3.0.0.14: NetCAM
      1.0.0.7: Restart
      3.0.6.8: SDJ-Health
      3.1.0.28: Sonos
      3.0.1.256: Z-Wave
      https://www.sysinfotools.com/blog/fi...age-malformed/
        I wasn't sure of the location or name of the log database but after a little searching found and deleted the file. It working again - thanks.
          Just to be clear, the log file is in the 'Logs' folder and is named "HomeSeerLog.hsd". If you delete it or rename it, HS will create a new one.
          HS3 Pro Edition 3.0.0.548
